Question about Panasonic Viera TH-42PZ80U Plasma TV
Power light blinking 10x - Panasonic Viera TH-42PZ80U Plasma TV
  • Anonymous Jan 23, 2010
    Well, Chu3505 appears to be correct!
    So, I called the geniuses at SEARS...thehy sent out a 35 year seasoned professional came over but had to get panasonic on the phone to help him trouble shoot...couldn't find it...so ordered a new power board...parts and labor $520.00
    Thats more than 1/2 of what I paid for this "floor display"
Anonymous
    New Friend:
It's not necessarily the power board. 10 blinks is the Miscellaneous error code. Your TV knows something is wrong, but isn't sure what it is. It can be any number of things, including bad boards. Mine, personally, was multiple bad boards.
Posted on Jan 05, 2010
Chi Chu
  • Panasonic Master
  • 8,457 Answers
Replaced the power board it dead.
Posted on Dec 22, 2009
Anonymous
    New Friend:
  • 12 Answers
If the power board blinks 4 times, you have to replace the Power Supply. Average charge for this kind of repair $370 to $510 Labor and parts.
good luck
Posted on May 01, 2010
Anonymous
    New Friend:
Power lights blinks 4 times
Posted on Jan 23, 2010
My panasonic 50 inch viera tv wont come on after
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 19, 2014 | Televison & Video
Hi. we have a few years old panasonic th-42px700. it was working fine last night til the wife tried it this morning. the power light is green but no picture and no sound. if you switched it on, the power...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 07, 2017 | Televison & Video
Problem with Sharp XR-10X The power light blinks red
According to the manual, a red blinking light indicates that the lamp cover is open. Try reseating the lamp and making sure everything closes up right. If the light is still blinking, it is most likely a problem with the projector itself and you may need to find out about getting it serviced.
Jun 27, 2011 | Sharp XR-10X Multimedia Projector
Power light blinking 10x sequentially on a 4y.o.
If you apply the 50% repair/replace rule, it's time to replace rather than repair.
Sep 21, 2017 | Panasonic (TH-50PZ700U) Television
Just replaced bulb when cold it has trouble lighting.
it's not the lamp, it's the ballast. when it's fully discharged, it needs too much power to start. once it has the caps charged (when it's been running and warm), it'll start right away. it sounds as if the capacitors on the ballast are drying up. best to replace the ballast. after you do, make sure the projector is free of dust and dirt. excessive dust will cause premature power and lamp failure due to lack of cool down.
Jul 07, 2009 | Sharp XR-10X Multimedia Projector
Red light blinks 10x then powers down, help me!
Go to this link and scroll down for info of the ten blinks.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Will give you some info of what to do next.
Mike
Mar 26, 2009 | Sony KP-51WS520 51" Rear Projection...
Sharp xr 10x
You will need to open it up and flip this little breaker switch. It has gotten to hot and tripped itself. Dust it out while you are in there.
Apr 26, 2008 | Sharp XR-10X Multimedia Projector
Panasonic Viera TH-42PZ80U Plasma TV Logo
1,995 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
