How to clear a purge unit error
Reset will not clear a purge unit error. Sometimes you can remove the purge assembly and clean out all the ink covering the moving parts. You clean with just water, most times I just replace the purge unit, around $30.00
Posted on Jan 15, 2010
When the printer is not functioning properly it may need to be reset. Make sure that this code is not being generated from a paper jam. Consult your manual for all the ways to check for paper jammed in the printer. (You may not be able to see the paper jam).
Then try a reset as follows:
1) On the printer panel, press and hold the <On/Off> button for one second (the display will go blank). If it does not, unplug the power cord.
2) Wait approx. ten seconds. If unplugged, plug it back in. Otherwise, press the <On/Off> button again.
3) Wait for the machine to cycle through its startup routine before trying a print job.
Posted on Dec 23, 2009
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Jan 17, 2010 | Canon MP610 Photo All-In-One Printer
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Oct 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Sep 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Mar 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Jan 22, 2009 | Canon imageRUNNER 210S Copier
Nov 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Nov 12, 2008 | Canon MP830 All-In-One Printer
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Feb 26, 2013 | Canon PIXMA® MP530 All-In-One Printer
Oct 10, 2011 | Canon PIXMA® MP530 All-In-One Printer
Aug 30, 2011 | Canon PIXMA® MP530 All-In-One Printer
802 people viewed this question
