Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
Posted by y0ur5un5hin3 on
Anonymous
    New Friend:
Ours is doing the same thing only screen goes green
8 quick blinks then a few second pause
Posted on Jan 05, 2010
Anonymous
  • 10,594 Answers
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Posted on Dec 22, 2009
1helpful
BLUE SCREEN My sony KP 46wt500 hdtv ready rear projection has
Ur tv have a problem known as convergence problems.Ur tv convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergencce problems.The shop will cost u $300-350 for parts and labors.
I have a Sony TV that needs help...model# KP-46WT500. Issue is, turned it on this morning and Red Green and Blue are no longer lined up. You can see three images in every color. it's looks better in the...
Convergence is dead.Must replaced 2 convergence ICS,and some or all it resistors.Can u do soldering electronics parts?Buy a convergence kit at websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
1helpful
Tried to use 2002 Sony TV as large monitor for webinar. Got the TV to accept signal but could never size the screen correctly. It only showed part of the computer image. Gave up on using it as large...
Symptom shows that it is convergence out chips failure that causing misaligned images on screen. Please replace convergence out chips in tv to get converge picture.
Question shows it is Sony KP-46WT500, if it is different model let me know please.
I can provide you more technical assistance if you wish to repair tv by yourself.
Thanks.
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
2helpful
Turn on the big screen sony tv, but fades to blue
You probably have a bad BLUE CRT. Due to the cost and the length of time it would take to repair, I would not invest the money into it. It would require a Qualified Service Person to come to your home and remove the BLUE CRT assembly and send it back to SONY to be rebuilt. Estimated cost would be around 800.00. I would check prices of a replacement set.
I hope this helps,
Skyassoc
2answers
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sony KP-46WT500 picture is distorted
you either need to reconverge the unit (auto focus) or you need to replace the converge chips-stk-xxx-xxx don't adjust anything.
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Sony KP-46wt500
inspect the neck boards on the picture tubes
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
