At the bottom of the screen there is a green and red arch. Magnavox 51'' rear projection
Posted by davidkelloug on
Joaquim Martins
    Genius:
  • 1,127 Answers
There is a Typical Defection Board N/S error, needs to be repaired. Go to local Repair shop to repair/adjust.
Posted on Dec 22, 2009
My magnavox tv has double letters in both red and green images on the bottom 2 inches of the screen
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
I have a 51 inch magnavox projection tv, the color started with a blue tint but now the red and green has gotten weird also. the screen is starting to have half circle or look bent also on top and bottom...
Ur convergence it dead,Know how to solders?Can buy a convergence kit,replaced what in the kit.Tries websites.Tv repair World.com,Tvrepairkits.com.To repair ur self.Cost u about $300 to repair by the the shop.
Dec 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
My 51 inch Magnavox rear projection has red and green overlapping
the coolant is bad inside the blue and green pix tubes-to verrify this you can remove the front edge of the screen(it pulls off-one edge at a time-take out screws to remove screen-after screen is off look down at blue/green tubes pix is bad or not there
Sep 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox convergence arch bottom of tv
you have a problem on your convergence driver board,either a leaky capacitor, resistor increased in value or a STK ic going bad
Mar 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence on Projection screen
More than likely the repair company used cheap chips when they did the repair. The cheap ones fail real quick. Goto the site www.TvRepairKits.com. They have built a kit that you can do yourself. It includes name brand chips and a photo instuction guide.
Dec 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 51" Rear Project Red Streaks
Sounds like the convergence IC's went south.
Jul 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arch on top and bottom of tv
You can try adjusting the convergence manually, but this is not a good symptom for your TV to have.
Look at this Quick Start Guide, p. 7:
http://www.p4c.philips.com/files/5/51mp392h_17/51mp392h_17_qsg_aen.pdf
Mar 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Green lines
This is the convergence amps going bad. You would need some tech experience. But could do it if talked throu.
Sep 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
