Question about Ovens
I have a arrow oven and when i plug it in and turn the socket on the oven turns on even tho the oven is in the zero position
Posted by mark_pear350 on
john koay
  • 39 Answers
Most likely the fastening screws on your knob might have come loose and shifted position. Turn the knob anticlockwise i.e.towards left of "0" position and see whether it will move. If it does, then your knob is loose. If the knob does not use a fastening screw, then the spring clip/the center hole of the knob is enlarged resulting in the knob shifting position. Replace the knob.
Posted on Dec 22, 2009
Top oven fan wont turn off unless I turn the cooker off at the mains
Cooling fan has the function to protect kitchen furniture from excessive temperature. The fan will cool the oven even you turn it off (not unplug from wall socket). This will happen only after the temperature decreasing below 70 degrees. If this does not happen then is faulty thermal cut-out which is located between wiring on the top and has 4 pins.
Dado
Sep 19, 2014 | Zanussi Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
What will make a oven come on with the oven knob turned to the off position?
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Jan 15, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
My Prestige PR1 S0 oven suddenly stopped working. I checked the socket it was plugged into. No power when other electrical item (radio) is plugged in. I plugged the oven into a gang socket which was...
It sounds as if the oven element short circuited and tripped the oven circuit. You will need to reset the oven circuit breaker or rewire the fuse at the switchboard.
If the oven indicator light comes on when you turn the oven on you will need to replace the faulty oven element.
Feb 23, 2011 | Ovens
Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Sep 28, 2009 | Ovens
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Nov 22, 2008 | Neff U1721 Double circotherm Electric Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Whirlpool Oven AKZ101/1X serial 858510115001 140349004758
Ensure the oven knob is set to 0 (zero) and press the reset button in the middle
Oct 24, 2007 | Ovens
Ovens Logo
125 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
