Question about Olympia Supertype 330 Typewriter
How to release margin right - Olympia Supertype 330 Typewriter
Posted by westlakehome on
Anonymous
  • 328 Answers
Space to the margin then touch the mar release key. If you want to change the position, then space to the new position and hit right mar key.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Dec 30, 2009
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
How to type in Landscape form of paper .
Roll the paper in sideways. Use the Margin Release key to allow you to backspace to the left of your left margin, then touch the Left Margin key to set the margin at the new location. Go to the right margin and use the Margin Release key again to allow you to space past the right margin, then touch the Right Margin key to set the new margin there.
Type.
Aug 18, 2011 | Brother GX-6750 Typewriter
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
I lost the manual for my sx-4000. How do I release the margins.
  1. Press "return" key to left margin.
  2. Press "margin release" key once.
  3. Backspace to where you want the left margin
  4. Press "Margin left" key.
For right margin, space bar to where it is, press margin release, space bar to where you want it, press "margin right" key.
Dec 10, 2009 | Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Our office has an ES 95 - for some reason we can not get the right margin to release?
Space it to the right margin. Press "margin release" key once. Space further to the right to where you want the new margin set. Then press the "margin right" key once. This should take care of your problem.
Aug 28, 2009 | Office Equipment & Supplies
Margin
Hi:
Just space to the right margin. Press the margin release key once. Space to the desired new spot for the right margin and then press the right margin key once.
Good Luck
Andrew
Jun 23, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Right margin won't release
Try touching the margin release key then the space bar to pass the margin then reset it in a new location with the right margin set key
Oct 16, 2007 | Brother GX-6750 Typewriter
Olympia Supertype 330 Typewriter Logo
108 people viewed this question
Top Olympia Office Equipment & Supplies Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ed
Ed
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
