Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint RFA52 fridge freezer
Hi my fridge freezer has stopped working, the fridge light is still on but it will not freeze or cool in the fridge.
Any ideas what the cause is and can it be fixed by me?
Posted by libbo on
  • libbo Dec 22, 2009
    thank you for your quick resonse.
    hi is it possible it has switched off because i put it last summer in a outhouse in the back garden, and with this cold snap in the weather. it is affecting the apliance?
    and if so will it switch back on once it warms up?
Danny
    Sergeant:
  • 160 Answers
If you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Posted on Dec 22, 2009
Testimonial: "thank you for a quick response A++++"
  • libbo Apr 28, 2015
    Hi I can hear motor running and have turned it of for 5mins and got no clicking sound?
maqso
    New Friend:
    Problem Solver:
Hi my fridge freezer has stopped working, the fridge light isoff it will not freeze or cool in the fridge.
Posted on Dec 08, 2014
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
1helpful
2answers
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
3answers
Will my mothers new fridge freezer work out in the garage
This is from the hotpoint web site.
If the room temperature drops below 14°C for an
extended period of time, the ideal temperature will not
be reached in the freezer compartment and food
preservation will be reduced.
You can read the manual here if it will help you.
http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19504293107_UK.pdf
Good Luck
2helpful
3answers
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Hotpoint fridgefreezer FFS70
if you have no cooling at all it means that a no gas charge b locked  in defrost c thermostat d compressor not working
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
