there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
I have the exact same problem. I had to look it up in the manual to fix it but if you follow these steps it should clear it out for you:
1. Open the flip and press "OK" 2. Press "2" to open the message screen. 3. Press the right soft key (the rectangular button above the keyboard). 4a. To erase received messages hit "1" then "OK" 4b. To erase sent messages hit "2" then "OK". 4c. To erase Drafts hit "3" then "OK" 4d. To erase all messages at once hit "4" then "OK".
LG VX9200 w Broken internal screen Clearing all txt messages (except locked)
with a closed phone from the external screen:
go to menu -> messaging
you should see{1. New txt 2. Inbox } and so on
open phone inside: press right silver key below screen press 4 press up press ok
you just need to get the external LCD replaced...not to worry most lcds on the v3 you can take out the external lcd without replacing the entire lcd....so take it to a repair center close to you.
