Question about Brother MFC-230c Printer
Have lost disc and owners manual on MFC 230C, can I get another copy of cd and instructions?
Posted by guy747 on
Mohamed Omran
  • 2,567 Answers
All drivers, software & firmware are available for download at this link:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc230c_us&type2=-1&os=all&flang=all&dlid=
Manuals are available for download at the same link, but you have to click the link in the "Manuals" tab to see them.
Posted on Dec 22, 2009
Wayne Mineard
    President:
  • 1,901 Answers
Here is the support page for the printer:
Brother MFC230C Support
There are links for manuals and also to download the driver for it.
If you need any additional help, just Comment back.
Thanks for using Fixya.
How to clear "unable print 51" in Brother MFC 230c printer?
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
Jul 26, 2014 | Brother MFC-230c Printer
SeeTroubleschooting and Routine Maintenace chapter in user's quite.see clean unable 51 to MFC-230C
Hello and Welcome to FixYa!
"Unable 51" is most likely a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your problem will be solved.
For any further help, you can take my valuable,professional help by taking my Service
Thank You for using FixYa
Mar 02, 2012 | Brother MFC-230c Printer
My brother mfc-230c keeps saying "paper jam" and there is no paper jammed in the printer
this is an error that could get stuck in the memory, try removing the paper tray then unplugging and replugging the printer then when it's warmed up replace the tray.
if problem persists you may have a broken sensor
Sep 27, 2009 | Brother MFC-230c Printer
Need to re-install my printer
Follow the link below and you can download the whole CD from this site, make a copy of that using ur CD/DVD writer and reinstall the printer.
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/dlf/download_top.html?reg=as&c=as_ot&lang=en&prod=mfc230c_as
Hope this will solve the problem
Sep 20, 2009 | Brother MFC-230c Printer
I dont know how to connect the MFC-230C printer to my Dell Computer...HELP!
Use the USB Cable supplied with your printer then connect it to your computer....your computer will automatically detect the new hardware then will ask if you have the install CD of your scanner, insert then install.....
Let me know if everything is going fine....
Apr 12, 2009 | Brother MFC-230c Printer
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-230c Printer Logo
196 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
