Question about Acer TravelMate 2300 Notebook
Error message: address 10001187 in ServiceControl.dll
I have an Acer Travelmate C200 and recently when I turn it on I get a message: address 10001187 in ServiceControl.dll write of address 004054E9. Any idea how to fix it or what it means?
Posted by satyava on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 13 Answers
Download dll files free at http://files.versionhunter.com/
Posted on Jan 01, 2010
Access violation of address 1001187 in module ServiceControll.dll write of address 00405555
How long has this been happening? Did you try a system restore?
(start>all programs>accessories>system tools>system restore)
or search system restore.
Restore the system to before this was happening. Keep in mind, any programs you've installed will be affected. Also you might have to update your antivirus.
Jul 01, 2012 | Acer TravelMate 6592G-602G25Mn Notebook
Acer eManager Monitor Program Every time my laptop starts i get the message Access violation at address 10001187 in module 'ServiceControl.dll'. Write of address 00405555. After I press ok it comes...
Open "My computer", right click on the C: drive and select properties, click the "Tools" tab, and click the "Check now..." Button under "Error-checking" Make sure both boxes are checked. A window will appear asking to re-schedule. Do so, than reboot your computer and let it do the repairs.
May 03, 2011 | Computers & Internet
ERROR MESSAGE: OPERATING SYSTEM NOT FOUND. ACER TRAVELMATE.
Do you have CD in your CD drive? If not, your hard drive possibly crashed.
Jan 24, 2011 | Acer TravelMate C111Tci Tablet PC
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Error messages on start up
i think you have deleted that .dll.. use a reinstallation cd of windows so that you can boot.. it worked for me
May 20, 2009 | Acer Aspire 6920-6621 Notebook
Need an audio driver: acer travelmate 2480wxci
The following is the site address where you can find all the drivers.
and don't worry about the no. because 2482 is a member of acer travelmate 2480 series. the drivers will work just fine.
just download and enjoy.
http://support.acer-euro.com/drivers/notebook/tm_2480.html
Apr 20, 2009 | Computers & Internet
Dialog box
Does the dialog box say Isass.exe not found !!! If so then it was corrupted by a virus and ur antivirus did a bad job of cleaning it... it modified/deleted it. Isass.exe is a system/servicecontrol file. If u have another pc copy Isass.exe from it..... Isass.exe is found in C:\Windows\System32
Oct 27, 2008 | Acer TravelMate 2300 Notebook
RTHDCPL.EXE err
Error Message after Installing Security Updates 925902 and 928843 This afternoon (April 3rd, 2007) my Automatic Updates alerted me about a couple updates I needed to install, so I did. Upon rebooting the computer though I was confronted with the following error message
"RTHDCPL.EXE - Illegal System DLL Relocation"
"The system DLL user32.dll was relocated in memory. The Application will not run properly. The relocation occurred because the DLL C:\WINDOWS\SYSTEM32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
Cause of Error Message
Turns out this error occurs when the Realtek HD Audio Control Panel by Realtek Semiconductor Corporation is installed. This is my built-in sound card on my computer.
The HHCTRL.OCX file that is included in the Security update 928843 and the User32.dll files that is included in Security Update 925902 have conflicting base addresses. When Windows loaded the HHCTRL.OCX file before it loads the User32.DLL file, the problem occurs.
The error occurs when the following third party programs or applications are installed on a computer with Windows XP Service Pack 2 installed.
ElsterFormular 2006/2007
TUGZip
CD-Tag
Microsoft now has released a patch to correct the problems, you can go to the following link to download and install the patch for the patch :-)
http://support.microsoft.com/kb/935448
Oct 18, 2008 | Computers & Internet
Hi need support
hi ben
have you tried running a chkdsk ? at start press the f8 key 4-5 times ask system to start on command prompt when you see the C:\ curser , type chkdsk press enter it may be your computer cannot access part of a program due to it being crosslinked
this has no guarantee to solve it because you may have actually lost or moved the .dll file. windoc.exe in norton utilities will fix this
Aug 30, 2008 | Acer Aspire 5610-4648 Notebook
Error message
"Access violation at address 10001187 in module 'servicecontrol.dll' Write of address 004054E9."
May 29, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
610 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
