I have the Canon iP 5200 and I have the orange light flashing 5 times, continiously! I have read the manual and it indicates that the The print head is not installed , or it is not properly installed and to Install the print head properly orPrint head temperature sensor
error or Faulty EEPROM. I have gone into the print head and tried to clean it but I am still getting the orange light flashing 5 times, can anyone help?
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair.
I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Orange light flashes 5 times.
Printer does not print. I am told this indicates a print head error, but how do I react. Can I clean the print head, and if so, how should I do it?
