Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
Child safety off
Need to get childsafety off
Posted by ndennis_38 on
John Morganti
  • 864 Answers
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Here is the manual. See page 16.
Posted on Dec 22, 2009
Child hit screen with ball replace screen or junk tv
Search Results
    [PDF]DX-LCD37-09-2 - Dynex Products
    www.dynexproducts.com/.../DX-LCD37-09-2_08-1430_ENGLISH_WE...
    Jan 15, 2008 - DX-LCD37-09-2 ... Connecting an antenna, cable TV, or satellite TV box . ..... Remember that children can become excited while .... Do not drop your TV or hitthe glass screen. If the screen breaks, be careful of broken glass.Missing: ball
    [PDF]DX-32L200A12 DX-37L200A12 DX-46L262A12 - Dynex
    www.dynexproducts.com/.../DX-32L200-37L200-46L262A12_11-1082...
    DX-46L262A12. USER GUIDE. DX-32L-37L-46L_11-1082_MAN_V2_EN.book Page 0 Tuesday, November 22, 2011 1:09 PM .... Using the on-screen menus . ..... CHILDSAFETY ... TV or hit, jolt, or press hard against the LCD panel. If.Missing: lcd37 ‎ball
Feb 03, 2016 | Dynex DX-LCD37 TV
Child safety lock is on, how do I unlock it?
The child safety lock on the car doors is usually controlled by a switch that is located along the outside edge of the door. Open the door and look along the outside edge of the door for a small switch. This switch sets the child safety lock to on or off. The switch may look similar to the photo I've included. If you still cannot find the child safety lock, please check the owner's manual for your car.
Dec 05, 2015 | Cars & Trucks
Non powered sliding doors will not open from inside....not a child lock issue
If, like on mine, the child safety lock on one side did not fully release due to a bit of a sloppy end on the activator. Had to reduce the slack a bit so the lock mechanism would fully clear.
Try this: Set the child lock to on...and then a 'fast flip to off' and see if it goes off on several tries.... mine did for a while...but reverted back to needing attention.
Apr 18, 2014 | Dodge 2007 Grand Caravan
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Child safety lock on 2003 pontiac grand prix
should be a switch on the back doors to turn on and off the child safety locks it requires your key or a flat blade screw driver.. let me know if this works for you
Apr 12, 2012 | 2003 Pontiac Grand Prix
How do i unlock my lg microwave i dont have an owners manual so i dont know how to unlock it
"Locked" meaning the buttons don't work/non-responsive (Child Safety Locked)? To Unlock/Disengage the Child Safety. Push and hold the "Clear/Off" button for 3 to 4 seconds. The Child Safety is disengaged - problem solved.
Nov 15, 2010 | LG LMVM2277ST Microwave Oven
CHILD SAFETY LOCK
If the model number you have this question posted under is correct, to cancel the child lock safety feature all you need to do is press and hold the zero "0" button for at least 4 seconds. The "LOCKED" indication will go away and you should hear two beeps. The instructions are listed on page 11 of the owner's manual. If you no longer have a manual, you can download or print a copy for FREE at managemyhome.com. Just type in your model number under the "Manuals" link.
If you have questions, or if your model number is different, please let me know. I hope this helps you.
Nov 14, 2009 | LG LMVM1935 Convection/Microwave Oven
Need instructions to mount Bell Classic Child Carrier
Bell Sports does not have a manual for your Child Carrier posted online. You will have to contact them directly.
(800) 456-2355 or e-mail us at [email protected]
I sugguest you have the child seat install by your local bike shop to insure the safety of your child.
Hope this helps!
Jul 13, 2009 | Cycling
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Child safety lock
Press "end of cycle" button for over 5 seconds, the child lock comes off. All the best, and dont forget to RATE me.....
Press it again and the child lock comes on, simple eh?
Nov 25, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
137 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
