Question about Cuisinart DCC-1200 Coffee Maker
Where is thermal fuse in cuisinart dcc-1200 it needs replacement
    New Friend:
The Cuisinart DCC-1200 doesn't appear to use a thermal fuse but instead seems to use a NTC Thermistor. Like thermal fuses this is clipped onto the bottom heating element and has two yellow fine lines leading to the control board. It should measure ~220k Ohms at room temp and drop its resistance to <20K ohms as water boils. This Thermistor looks and behaves a lot like a Vishay NTCLG100E22245B [220KOhmn] which is available through DigiKey [BC2467 part number; $0.52]
Posted on Nov 30, 2010
NORMAN ZINK
  • 85 Answers
SOURCE: Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
Posted on Jul 08, 2009
Canster cover will not stay on can i get a new one? dcc 1200
Hello, George -
I am sorry it was too difficult for you to go to the Cuisinart web page for parts for your Cuisinart DCC 1200 coffee maker.
This is the link to the web page where you can purchase a replacement carafe lid or a complete replacement carafe:
https://www.cuisinart.com/parts/coffee_makers/dcc-1200/
Best wishes.
Feb 12, 2018 | Coffee Makers & Espresso Machines
Mr recall
Cuisinart may be able to supply a switch or you can try an appliance parts supplier.
Jul 20, 2014 | Cuisinart DCC-1200 Coffee Maker
Can I get a manual on how to work the coffee pot
Here's the download link for the manual: https://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
Apr 02, 2014 | Cuisinart DCC-1200 Coffee Maker
Does nothing when plugged in. no lights. power is good. tried other outlets
MOST consumer heating appliances have a thermal fuse. They look like a small silvery bullet shaped part with a wire from each end. If the appliance overtemped, teh device opens permanently and has to be replaced. It would be mounted very near the heating element.
Oct 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
See post on Cuisinart customer service. The tube can be purchased at Lowes. Clear vinyl 1/2" O.D., 3/8" I.D. The compression clamp will have to be replaced as well.
I used a 1/2" hose clamp available at any auto parts store.
Aug 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
4,358 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Pierre Laplante
Charles Tidwell
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
