Question about Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive
WD ELEMENTS 1TB and the power supply is blinking
I have a WD ELEMENTS 1TB and the power supply is blinking and the drives does not work when i pluggin the usb.
    New Friend:
Don't lie. I have wd drives that all use the same power supply. Swapping out doesn't change anything, and formatting doesn't fix either. Google is full of people mad mad mad about this.
At this point the logic board is broke. You can pop it open (great how to videos on youtube takes 10 seconds) and use the drive as an internal SATA drive, or buy a third party external drive enclosure and use it that way.
Posted on Apr 05, 2013
    Guru:
  • 1,738 Answers
You have a bad power supply. You can probably get a new adapter for it.
Posted on Dec 21, 2009
6ya staff
SOURCE:
WD elements SE 1TB Portable hard drive will power up and disk will spin but not showing up in my computer....
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, and you'll get a significant discount.
Nov 04, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
Why wont my wd elements 1 tb hardrive work on my ps3??
1) It needs to be FAT32 PLUS it needs to be externally powered. I found out the hard way that the PS3's USB ports do NOT provide enough power for a standalone USB hard drive, so you need to add your own power supply.
Dec 09, 2009 | Western Digital My Book Essential 1TB...
I purchased 2 WD elements 1TB. I have pluged it
right click on the drive , format it and it should work, if this not solves your problem go to the shop and use your warranty, it may be broken.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
No power supply to NEW WD 1TB
If you just bought it I would take it back to the supplier for testing under warranty.
Sep 14, 2009 | Western Digital Elements powered by WD 320...
WD elements 500GB -
Had the same thing .... called them and they gave me a RMA for a new drive .....
Jul 22, 2009 | Western Digital Elements powered by WD 320...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
1,878 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
ChinthakaJ
ChinthakaJ
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
