Question about JVC DR-MX1 DVD Recorder/VCR
How Do You Finalize the DVD after Recording it?
Posted by machinehe520 on
Anonymous
    New Friend:
On remote control press 'Setup' button;
'DVD Video Setup' tab will be highlighted;
Using arrow keys around the 'Enter' key, press right arrow once to move to adjacent tab called 'HDD/DVD Setup';
Press down arrow once to move to 'HDD Setup' tab;
Press right arrow to move to 'Disc setup' tab;
Press down arrow to highlight 'Finalise' button;
Press 'Enter' and follow on screen prompts.
Posted on Nov 03, 2010
How to finalize dvd recording
The user manual is at this link.
http://www.manualslib.com/download/55356/Funai-Mwr10d6.html
There would normally be a menu option to finalise the disc.
Nov 22, 2013 | Philips Magnavox MWR10D6 DVD Recorder
I have a jvc dr-mv150bj. I am knew to recording on DVD. I used the dvd to record the super bowl. I forgot to finalize and I was using a portable LCD projector. I unpluged the dvd recorder and took it...
finalizing completes the process of recording so that the disk can be read to play. Yes, probably if power goes off, you'll loose the recording as the disk can finish.
Basically, the code written at the end of recording creates a sort of index so the player knows how to read it.
May 02, 2017 | JVC DR-MV150B DVD Recorder/VCR
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
Do you have to finalize after recording from a camcorder they both are sony camcorder and sony dvd recorder
Yes. Any dvd disc recording has to finalize. This is the same for audio and video cd or dvd recording.
Oct 24, 2009 | Televison & Video
Wont read dvd+r
This is a pretty generic problem with dvd recording on combos. The problem is that after you record to the dvd there is a procedure that is on your menu using your remote to finalize the recording so that it can be read on different players. Otherwise it can only be read on the one you recorded on. Go through your remote control menu options after the recording and look for the option that indicates finalize recording.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Finalizing DVD
If the size of the vhs recording was in 2hr mode, and the size of the recording itself is about 2 hrs, you may not have enough space to finalize. I would use your PC to finalize the disc - I use Dr. Divx, but you can find many finalizing programs out there.
Sep 04, 2008 | Zenith XBR413 DVD Recorder
DVD-RW will not finalize after recording
There is no solution for your problem. I thought my 4500 wouldn't finalize also but what is happening is that it didn't record on the disc you used. This is an older model unit and will not record on 16x discs. I believe you are boinked.
Feb 13, 2008 | Sansui VRDVD4005 DVD Player/VCR
Finalizing a recording
After you insert your DVD wait till recordings page comes up then press EDIT key then press left Arrow then Down arrow to FINALIZE..
Jan 19, 2008 | Cyberhome DVD Recorder - DVR1600
How long does it take to finalize? Can I finalize on other recorders?
The finalizing time depends on the remaining time on the DVD-R disc; Approximately 8 minutes to finalize with 20 minutes recording time on disc Approximately 3 minutes to finalize with 10 minutes recording time on disc Approximately 2 minutes to finalize with no recording time on disc. DVD-R discs recorded on the DVD-Camcorder cannot be finalized on other DVD-R Recorders or PCs.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
JVC DR-MX1 DVD Recorder/VCR Logo
233 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
