Maytag CWE4800A Electric Single Oven Logo
Posted on Dec 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A MAYTAG BUILT IN OVEN THAT WAS WORKING FINE LAST NIGHT AND GET UP THIS MORNING TO BAKE AND I AM GETTING, ITS FLASHING A F2 AND F7 ERROR CODE AND THE ALARM OR BEEPING IS GOING OFF
Anonymous
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on Nov 10, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
56915
Points
313
Hi You have a bad touch pad , there maybe a be a button stuck in , try running your fingers over all the touch buttons but i think the touch pad will need to be replaced as always remove the power before taking it a part
2answers
Code F7 flashes, after a few minutes, when oven is set at 400 in convection bake mode.
Question edited for clarity and all the typos.
All questions need 'make model (what it is)' as first 3 words.
Generic advice on a generic F7 Oven Error code.
F7 error code can be a result of a faulty wire harness (short-circuit), defective heating elements or oven sensor. A qualified service technician will need to have a look, determine faulty part then replace or repair it.
Apr 27, 2023
Help library: Electric Range: "F-7" error code - troubleshooting
https://www.google.com/search?q=Oven+Error+Code+F7
Oct 06, 2023 • Ovens
Maytag model CWG3600AAB error code f2
There doesn't appear to be an F2 error code! There is an F1-2?
https://www.google.com/search?q=maytag+gemini+double+oven+error+code+f1-2&
There may be a problem with the Lower Oven Temperature Sensor, the Control, or the associated wiring.
Maytag - F1-2 - Product Help
F7 error code jenn-air wall oven
My 20 year old electric Jenn Air range recently flashed the F7 error code and beeped repeatedly. I shut off the circuit breaker until it cooled. The next day I turned it on and everything seemed fine. We baked a pizza and the
erro repeated when the oven was shut off.
I opened the front panel and noticed the wire ribbon connecting the front panel to the display was slightly askew. How that happened is beyond me. I pulled out the ribbon hold down clips, pushed the ribbon in all the way, and
replaced the hold down clips. The range is now working properly after replacing nothing.
The cheapest fix possible.
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 • GE Ovens
It's the middle of the night and pouring rain Christmas night and the F7 alarm is going off on my wall oven. Help! What do I do to make it stop?
Hi, Will forgo all the greetings. F7 is a stuck or shorted keypad. Try rapidly running / fanning your finger FLAT across the keypad to un-stick it. If this does not correct the problem you may be faced with either a keypad replacement or an electronic range control replacement.
Fault codes:
http://www.repairclinic.com/Fault-Codes#GE4
Thanks for choosing FixYa,
Good Luck!
Kelly
I am getting an F2, then an F5 followed by sometimes an f7 error code and inconstant temps.
the f 2 code is ( oven too hot ) the f 5 ( watchdog circuits disagree / and f7 ( function key shorted or stuck button .. / the clock ( erc ) may have a warped face . ..I would first replace the tempt sensor in oven . if you still have problem repl clock. and problem over .. thank mm ..
3helpful
2answers
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
2helpful
7answers
F9 error
hi there,
can you tell me the model # on your stove please?
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
