Computers & Internet Logo
Question about Toshiba Satellite M55-S329: M55-S329 Pentium M 750 [1.86GHz, 2MB L2 cache, 533MHz FSB], Windows XP Home Edit... (SATELLITEM55S329M55S329) PC Notebook
NO SOUND DESPITE AUDIO DEVICE WORKING PROPERLY
Posted by adi_sro on
Anonymous
  • 71 Answers
Try going into device managerNO SOUND DESPITE AUDIO DEVICE WORKING PROPERLY - 2_bing.gif
click start
then control panel
then NO SOUND DESPITE AUDIO DEVICE WORKING PROPERLY - 2_bing.gif data-src="/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" />
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
even if there is no yellow !mark follow the steps and update or re-install the driver
Hope this helps
Posted on Dec 21, 2009
Firewire inputs do not work
Check in the computer "Device manager" if a PC with windows, and see if there are any devices with an yellow "X" through them- the port may have an interrupt conflict.
Then check audio properties of the system to make sure the devices are selected and enabled, and their volume level is up- even if you are operating through the Mackie software console.
If a Mac- check the Chooser to make sure that input device has been selected.
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
2answers
In my Destop system Audio Sound is not coming
Check the device manager for any conflicts with the drivers. There would be "Other drivers" listed if there was any drivers that were not installed correctly. If there is any listed try right clicking on them and selecting to reinstall drivers.
To get to the device manager:
Right click on my computer or Computer > select properties > then click on hardware tab on top then device manager or click on device manager link.
Computer Repair - Support
www.jdtechsource.com
1helpful
2answers
I have a system of intel d101ggc boar but problem is that the sound could not recorded from mic
conform audio driver working properly or not. then open control panel & opene Sounds and Audio Devices Then click on Audio then select your default device in Sound Recording then click on Volume & increase the Volume for Full Then Apply & ok.
I hope that this has been very helpful for you
2helpful
DESPITE PROPER INSTALLATION OF SOUND CARD SOUND IS NOT COMING
When you download and run the sound file, it expands the file and copies it to your hard drive, take a note which folder it has created (usually C:\Driver\) Then open the audio folder and run the Setup program to install the audio driver.
Please help me
If after connect your usb speaker cable the system it is asking for software (drivers) you have to install them to get your audio working properly. Check it out the box of your new speakers for a installation CD.
You can also verify:
Check if your audio es working properly (start >> control panel >> sound and audio devices)
Check if your sound card is properly installed (My pc >> Properties >> Hardware >> Device Manager >> Audio)
My sound doesn't work for anything!
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
2helpful
NO SOUND AT ALL
First check if the onboard sound is enable on your computer's BIOS, so restart your pc and press the DEL key on your keboard so you can access it then make sure the audio is enable if its disbale enable it then try now if it will working.
If the audio is enable on BIOS and still no sound check if the audio is installed properly under device manager Right click on Mycomputer>properties>hardware>device manager>then look for the audio device that should be enable and working properly if not you need to reinstall the driver for it.
Top Toshiba Computers & Internet Experts
David Shaub
Steve Sweetleaf
Steve Sweetleaf
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
