change unit name
press additional functions button
then use the arrow - + buttons to select tx/rx settings press ok
tx/rx common set.
tx settings
unit name
You can send a fax to up to 142 fax numbers, using any combination of dialing methods:
- One-touch Speed Dialing (up to 32 destinations)
Press the desired One-Touch Speed dial button(s)
- Coded Speed Dialing (up to 100 destinations)
Press [Coded Dial] > enter the 2 digit code (00-99) using the numeric buttons and be sure to press [Coded Dial] before each code
- Regular dialing and redialing (10 destinations)
Enter the number using the numeric buttons or [Redial/Pause] and be sure to press [Set] after each entry with the numeric keys
After all the numbers are listed, press [Start]. The machine will scan in the document (memory) and then begin sending it to the destinations in numerical order, starting with One-Touch, then Coded and finally the numbers dials with the numeric keys.
You can also create a group if you frequently send faxes to the same group of people by first saving them as One-Touch and then adding them to a new group.
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending. http://www.actcopiers.com/Manuals/Canon_Laser_Class_2050P_User_Manual.pdf
Press the dataregistration key.dataregistration will apear on the screen press the arrow down untill Tellregistration will be displayed.Press set or ok or start.! Toutch speed dails will be displayed.Press set or ok or start.It will show the available one touvh numer.Enter and insert name and fax of the sender.
All the numbers saved in group dail,are separatly saved in the one touch speed dails,you have to locate that fax number in one touch dails and change it there.
If you followed the procedure F 7, 2 set, 1 for speed dial, enter your free speed dial space, enter your fax #, set, enter the name, set.(continue to next free speed dial key or stop) If this doesn't work then you may have a bad battery on the main board that saves the data if the power goes off.
