Question about Philips FW316C37 Shelf System
My stereo won't read the disks inserted in my CD player
I have a 3-disk CD stereo player, and when I insert CD's they won't play; the stereo won't read the disks. Help
Posted by shereeitza on
Grubhead
  • Philips Master
  • 5,700 Answers
All you can do is get a lens cleaner and hope that clears it up, otherwise you are looking at what might be an expensive replacement of the CD/lens/laser unit.
Posted on Dec 22, 2009
Vw beetle cd player wont read
The player may need replacement, especially if you have used it for more than a few years
May 08, 2013 | Car Audio & Video
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
TDK player reads CD disk but quits and does not play
your cd drive lens may be damage and lens preset will be not currect position so if you want to repair you cd drive then you have to turn your cd drive lens preset to currect position.
Dec 22, 2008 | TDK (ai-4800drombx-b) CD-RW/DVD-ROM...
Toshiba DVD player
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
Feb 05, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Malfunctioning cd player
Did you try taking out that lttle circle thing that you put your cd into.Well,take that out and then clean it.Then,insert it back and it should play your cd
Dec 15, 2007 | Audio Players & Recorders
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Jun 30, 2007 | Emerson MS3100 3-Disc CD Changer
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Philips FW316C37 Shelf System Logo
372 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
