Question about Panasonic Audio Players & Recorders
On my panasonic sc-ht05 I get an error code f76 telling me the power supply is dead. A recent power outage and restart did it. Can I replace the power supply or is that something only a shop can do? Would it be cost prohibitive? If so, can I use the subwofer and speaker with another system? Thank you. Glen
iain rehorst
    New Friend:
Here is also something to look at.
http://forums.whirlpool.net.au/archive/2244288
Fix for the famous f76 error code.
Posted on Apr 17, 2018
Costin Draghia
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Only a trustable service can do it.
Yes, you can use the speaker system with other amps but consider the max. power and impedance.
Posted on Jan 04, 2018
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Posted on Apr 06, 2007
robotek
Graeme Ross
  • 1512 Answers
SOURCE: cd player fault quick fix any one?
You can do a few things to see what may happen.
  1. Check the spindle height. The platters sometimes slip down the shaft, or the spindle motor bearing drops and the platter gets closer to the lens.
  2. check that the spindle motor has not become lazy and "poling". give it a few spins. then try to read a disc again.
  3. Clean the laser lens with a cotton wool bud moist with windex glass cleaner. Then "polish the lens with a dry one.
  4. the spindle motor top bearing is worn and the payer mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. More likely to happen at the start of a disc, because the disc is spinning fastest whilst reading the TOC.
A drop of light machine oil from a syringe oiler can help the bearing to spin an not produce the knock. Only a short term fix to give the motor a "lube". Once the oil leaches out of the worn bearing the problem will return. I have run motors immersed in an oil bath to rejuvenate them before... but better to replace it anyway if its suss at all. Good luck, You could bump my profile by giving me a "FixYa" rating for my sharing my "knowhow". Any problems check back with me here.
regards
Graeme.
Posted on Feb 10, 2008
Anonymous
  • 87 Answers
SOURCE: Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Posted on Apr 01, 2008
Anonymous
SOURCE: Panasonic SC-PT467 Wireless speakers Clicking
I had this exact problem. The clicking is something to do with interference from the power supply cable. It seems that facing the wireless unit in the most obvious way ensures that the power cable and the right speaker cables cross. All I did was turn the unit around so that the wires no longer crossed and magically the clicking sound disappeared forever!!!
Good luck !!
Posted on Feb 04, 2009
Anonymous
  • 407 Answers
SOURCE: I cannot read the manual for panasonic sc-ht07 (English ?)
You can download your user manual here
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
Posted on May 13, 2009
I have a panasonic SC PT960 system. Haven't used in months. Turned on,got error code F76. Tried unplugging and plugging back in to reset, but it did not work. What is wrong with my system?
"F76" is a power supply problem. Could be something really simple or something much harder to figure out. These units aren't really user serviceable and it's way too old to still be in warranty(?) so maybe you've been whapped with a subtle hint to upgrade to a blu-ray HT system. You'd be able to keep the rest of the system and just replace the head unit.
Jan 02, 2017 | Panasonic Audio Players & Recorders
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Nov 30, 2012 | Panasonic SC-HT40 System
Fault code for sa ht 17
Hi,F76 is the error displayed when the fan goes faulty in the unit.
Aug 11, 2009 | Panasonic SC-HT17 System
Jan 20, 2009 | Panasonic SC-HT07 System
Panasonic TH-42PX60B
THE 10 flash code is for the power supply
The Seven flash code is for the SC pcb (ysus) it is best to change the SC, SU, SD pcbs as one can take one of the others out
and if you add a new SC and one of the others is faulty then you will have another dead SC pcb
May 03, 2008 | Panasonic TH37PX60 37 in. Plasma...
Error Code SC 541
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
Apr 06, 2007 | Panasonic SC-EN17 CD Shelf System
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
1,124 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
