Question about Samsung DVD-VR330 VCR and DVD Recorder
Will only play about half the dvds that we put into it. once in awhile if you turn it off and on it will read the disc.
Posted by harvey98584 on
Anonymous
  • 687 Answers
This sounds like the spindle is not spinning the media you may need a new motor, take the top off to see if when you press play the dvd spins this will confirm this
Posted on Mar 05, 2010
After recording a programme it stops half way through when playing it back this happens occasionally we are unable to carry on with the recorded programme once it stops
Try to play a couple of dvds on another dvd player thru the point yours stopa to see if the recording is bad or the player portion is defective. Also is unit under warranty?
I put Cd of Xbox360 game...It gives me a message"To Play this disc put it in Xbox 360 console". Please tell me what I do to play game having such meassege.. regards..!
1. all the disc are not region free , games from microsoft are region free, which means u can play in any kind xbox 360
xbox has different version like (ntsc, pal), some countries only accept ntsc some pal.
u can find it on right hand side of the dvd
if it is pal u can play omly pal dvds
u can also modify ur xbox360 this u cannot do by our own, once u modify u can put both version of dvds
hope u got the answer
Ps3 only playing dvds and once and awhile 1 game cod,
are you useing the linux or windows based ps3..there is a differnce ..firmware updates with the windows based systems..and try updateing the software with the linux based systems..but prolly firm ware for the drive..
Screen blanking out, turning everything redish, or blueish, etc.
the IC on the board needs replacement  as they r at there last stage.
New game freezing about half way through
I don't think this is your xbox having a problem. This happened to me with Gears of War 2 once I just played over the game in the same spot over and over and it eventually stopped. This looks more severe for you though. It may just be a faulty game so best you can do is call the game manufacturer.
Pixilation when playback of dubbed and homemade DVDs
As mentioned on the Jan12 e-mailed Panasonic - surprise, no response! However on Panasonic's web site drill down to firmware upgrades for DVD machines. There is an upgrade available for the E50P. Straight forward fix, download to computer, expand it and copy to a CD-R. Put CD-R into E50 and recorder will check and update firmware. I did this on the 13th and have recorded two commercial free movies and both have played back perfectly after finalization. Time will tell. Hope this helps. Golferdon
DMR-ES10 DVD Recorder T112 error message
Can you press Enter when you get the error message? That will tell it to diagnose the problem. Tell me if that works. The manual can be found here. I can't find the T112 error you mentioned though.
http://panasonic.ca/PDP/OperatingInstructions/dmres10s-oi-eng.pdf
Reply if you need further assistance.
Samsung DVD-VR330 VCR and DVD Recorder Logo
Ekse
Demonic-2011
Demonic-2011
