Question about Reddy Heater-170,000 BTU Kerosene Deluxe
IGNITER SWITCH Where do I get an igniter switch? I live in West Columbia South Carolina. (125T Reddy Heater Professional series serial#016827588) Thanks Theresa Zeman office # 803-356-3476 cell# 803-730-6014
Posted by nettie497 on
Anonymous
    New Friend:
  • 160 Answers
If you have one of these 125T Models- RH125AT, RHD125AT, RL125AT, RM125AT, RE125AT, M125AT, PKHD125T, TKU125T, UKU125T, RD125T
The web address is:
http://www.reddyparts.com/
There are 3 ways to order your part.
Posted on Dec 21, 2009
I have a Reddy heater 125T and the transistor for the ignition is burned into, i was wondering if it is possible to solder a new transistor to the board, and if so what would be the part number for the...
Yes, I have done it and got transistor from a electroic story. took old one to them and they match it. When soldering it on use very little heat not meld the other solder tracks. Ken'Repair
Jan 22, 2011 | Reddy HEATER RH125T 125,000-BTU...
I have a reddy heater 125t.Is there a parts dealer in the dallas, fortworth area.
Sears or Home Depot sell products and parts ... other than that.. hard to find
Jan 30, 2010 | Reddy HEATER RH125T 125,000-BTU...
170T will not kick on when I plug it in and turn the switch on. I have power the the switch and the thermostat but no power past the board.
I have a 125t that would do a similar thing, found out that on the board a micro resistor or diode whatever would short and fry the board. Check your board carefully following the lead from the igniter wires. Hopefully that is not the problem because then its a new $$$$$ board!
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a 125t and the igniter works,it is getting fuel and still won't lite. Can you help?
Nov 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
RH125T won't fire
Not much to check. The element comes out and makes a square loop back to the ceramic portion. This element is extremely brittle and will break if touched or wiped off.
You can check the 2 wires with a voltage tester set on continuity. The needle should swap sides if the ignitor is intact. I don't ever remember an ignitor failing, except for breakage.
View this page. Be sure you get the correct ignitor. 2 different ones have been used on the RH125T.
http://www.reddyparts.com/125T%20ignitors.htm
Dec 28, 2008 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
569 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
