Question about Hotpoint First Edition WMA22 Front Load Washer
I have a hotpoint aquarius df740 washer dryer
The dryer is not heatin up is there a filter to clean or a water collection to empty, be grateful for any help
Posted by dionnenles on
hotpoint jon
    Sergeant:
    Champion:
  • 353 Answers
This is a heater circuit problem.check the heater element first
Posted on Dec 21, 2009
Aquarius TCL780 keeps beeping
your pump may not be working then it beeps
Dec 09, 2013 | Washing Machines
My Hotpoint Aquarius Condensor Dryer seems to be collecting water behind the filter unit at the bottom of the machine. The drawer where the water is supposed to collect is empty. I keep the filter unit...
there is a line/tube the runs into the back of the drawer which is clogged, you will need to take like pipe cleaner or a stiff wire and run it into the the drain line/tube , Tim
May 29, 2011 | Dryers
I have a hotpoint wd640 washer dryer: are you meant to clean the filter for the dryer, and if do where is it?!
The dryer part of the appliance does not have a seperate filter to clean as such, as the fluff and lint is cleared away by a constant supply of cold water coming in on the drying cycle.
Jan 12, 2010 | Hotpoint Aquarius WD640 Front Load...
My aquarius wd640 is not emptying and is now leaking from the front and where you put the powder helppppppalso i cant find the filter
Remove lower rear cover of washer, locate and remove large black hose, remove and clean filter inside hose.
Please rate my solution.
Thanks.
Jul 28, 2009 | Hotpoint Aquarius WD640 Front Load...
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Jul 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wt741
In most machines the filter is located under the panel in the bottom of the machine (the panel under the front door).
If u have manual refer; pull the panel out and you will find the filter there.
Before you open the filter keep a bowl & cloth to collect much water.
Mar 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint First Edition WMA22 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
