Posted on Dec 21, 2009
How do i set time for an Accurian 40-141 iPod Alarm Clock with Radio?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 03, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4961
Points
47
SETTING THE CLOCK TIME: 1. In standby mode, press and hold MODE to enter the clock time setting mode. 2. Press |<< TUNE/SKIP >>| to switch between 12-hour and 24-hour display. Press MODE to confirm the selection. The digits flash. 3. Press or hold |<< TUNE/SKIP >>| to set the hour and minute. Press MODE to confirm.
Can't find my manual to my Accurian docking alarm clock with radio manual
Try manualslib.com, or MFG website, or their customer service email.
4helpful
Just purchased, didn't have any instructions in box. How do I set time and alarm? Thanks
Clock: With the radio off, press the Clock Set button, then the Memory button. The time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
Alarm: With the radio off, press the Alarm Set button, then the Memory button. The alarm time will start blinking. Use the Hour and Minute buttons to set the alarm time. Press the memory button when you have set the correct time.
20helpful
2answers
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
1helpful
Lost manual for a accurian 40-141 docking alarm clock with radio
  • i have a AM FM digital dual alarm clock radio. dont no how to set it there are nemders on the back of it.cr4004DT 0506098496
12helpful
Can't set the clock
Ensure the radio/AUX/Ipod is off (hold down the power button)
Press & hold MODE until 12:H flashed. Use the TUNE/SKIP buttons to make your selection
Press MODE again to see the hours flash and again use the TUNE/SKIP buttons to set the hour
Press MODE again to see the minutes flash and use the TUNE/SKIP buttons to set the minutes.
Press MODE again and you are finished.
To set the alarm: Press and hold the ALARM button until the time flashes and then use the TUNE/SKIP buttons to adjust.
Accurian alarm clock/radio w/ipod dock
so you learn a lesson, the first thing to do is get the paper work together and pack it up and bring it back for credit. my advice is any time you decide to buy anything it is wise to go in the internet
and get a review of what ever you are buying you'll have a better
idea of what to buy.
92helpful
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
 Grubhead
Grubhead
SmartAviator
SmartAviator
