Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates
the need for crossover cables or uplink ports. The DES-1016D is the
perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T
networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
This switch is a plug n play device. No need to configure anything for basic use.
If you want to go for advance settings, You can log into the switch via webconsole and then providing the username and passwords you can loin and do the advance configurations like VLAN settings, Speed/Duplex settings, QOS settings etc
Normally most internal LAN addressing is carried out by a DHCP server which issues IP addresses to anything that is connected to the network. IE your computer. most switches are set to obtain an IP address from them as a default. to find the IP address of youe switch you need to look at your DHCP server ( possibly your router/modem) and see what addresses have been issued. Once you have found the address it is a simple task to open your internet browser and type in the ip address of your switch. once there you should be able to configure your switch as per your requirements.
hi,
in the web browser type 192.168.1.1 and enter password and login name as"admin" ( or if you have change login and password then enter that) and you will get the configuration page...
Hope this has helped you..
Thanks...
set u r borad band router/modem to dhcp and set both system to auto detect ip address put u r boradband ethernet cable to hub and both pc in same hub that it nothing to do with configure
enjoy!!! need help for router/mode to configure tell me the model number i will tell step by step
