Are the coils under the thing clean was the cover on the back left off,it needs to be on there. is the fan under there working? is the fan in the freezer running. is there anny frost bilt up on the inside back wall of the freezer, there should be none. door gaskets good all the way round, look closely.
The doors should be warm. There or heaters in the doors or what they call a yodelers loop in the frame around the doors that keeps condensation from forming. Make sure the fan if blowing on the compressor and the fan inside the freezer is also running. If so be sure there is no ice built up on the bottom inside back panel of the freezer. If so you will have a defrost problem and the coil is full of ice and not allowing the air to flow through it and cool the fridge. If there is ice, the heater behind the panel is most likely bad.
