Question about Dishwashers
Amtrol 41 hot water maker :not working when calling for hot water,contols are on showing temp,but tank is cold.oil fired boiler is fine,the whole system is 5 yrs old.
  • Dishwashers Master
  • 43,501 Answers
The problem is probably with the circulator pump or the zone valve, which ever way your water circulating from the boiler is controled.
The water needs to be moved through the boiler and the coils in the Hot water maker to heat water. If this is not happening then no water will be heated.
Check for power and then is the pump is running or the zone valve opening.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 21, 2009
6ya staff
SOURCE:
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Amtrol wh-7p
The tank rusting itself shut is almost an impossibility due to pressure. I would be inclined to believe that the controller is starting to fail and water that was way too hot entered the system and caused and overpressure issue that made the leak, When the pressure and temp dropped, the problem subsided. According to some of the threads that I have found on this, Amtrol is pretty generous about replacing the defective parts even when they dont have to. http://www.doityourself.com/forum/water-heaters/335226-amtrol-boilermate-problem.html
Jan 24, 2014 | Water Heaters
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
AMTROL Boiler Mate no hot water
You might have bad faucet cartridge or check valve.
Possibly a clogged line.
Contact amtrol [email protected] to hear them suggest calling local technician
Otherwise Amtrol does not post service information or service manuals.
Post question on pro water heater forum to hear them suggest a few things before you call local service technician.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Use search feature on forum above, before calling local service technician
Read suggested answers at fixya before calling local plumber.
Call amtrol and ask why they do not post service manuals or service information when so many promoters are selling the product.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 17, 2013 | Water Heaters
Hot water not lasting long enough
Check for crossover to eliminate plumbing problems:
http://waterheatertimer.org/Crossover.html
Mar 18, 2013 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
Wh 9L amtrol water heater..the water temp is too hot.. the heater is 10 yrs old is it possible to remove the temp probe and clean?
Amdrol makes indirect-fired water heater that gets heat from a boiler
http://www.amtrol.com/boilermate.htm
1) Pdf manual on amdrol website show a mixing valve that mixes cold water with the hot water so water temperature going to faucet stays the same:
http://www.amtrol.com/pdf/MC10169%20BMconstantempflyer.pdf
You set the temperature of the mixing valve.
You can also set up 2 sets of pipes ... one is connected to mixing valve that goes to sinks and tubs. The other pipe bypasses mixing valve sends hotter water to washing machine.
2) The manual for Amdrol:
http://www.amtrol.com/pdf/9040-586%2001_09%20BoilerMate%20Indirect%20IO.pdf
The new models has a temperature sensor that plugs into digital readout.
This is a thermistor sensor wire that can be ordered as repair part
3) Amdrol has e-mail address:
[email protected]
4) You can post your question on a water heater forum
Nov 11, 2010 | Amtrol Water Heaters
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
Dishwashers Logo
250 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
