Sounds like your water has been off for maintenance. This will make a sound like this but the rest of the faucets would have done it also when you first ran water through them the first time. So if you have a filter on your fridge, remove it and re prime before putting back on. If not, look at the back, bottom where the water supply connects to the back. Have some one try to get water in the door while you hold your hand on the valve where the water supply connects. See if it vibrates and makes the noise. Also follow the line and see if you have two different water valves. If so do the same with it. One should be making the noise if your filter does not have air in it. Good luck.
Noise from water dispenser very loud clacking sound
