Question about Olivetti Lettera 35 L Typewriter
A few keys are sticking on my Olivetti. They click up, hardly hit, and then dont return to their proper place. I'd appreciate it if someone could offer some advise...or name a place in Gainesville Florida where they repair typewriters. Thanks you, Sarah
Posted by smitchem846 on
Anonymous
  • 328 Answers
Needs a good cleaning and lubrication. I charge $ 75.00 to make it clean as new. You can try to simply lubbicate it yourself. Just drop 1 drop of oil into each typebar guide. Hit each key a few times.
My number is 727-773-8973 in Largo, Florida
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Dec 30, 2009
How do i put the chicklet key back onto the keyboard
Just put it in place and hit it with a 1 hard and accurate hit so it sticks to the placers..
Mar 19, 2013 | Acer Computers & Internet
How do I put lift off tape in my typewriter olivetti ET compact 60? Do you know which of the two yellow rings (the coged or the smooth) with the tape that must be in which side (left and right)?
Can't picture your machine but if you lift the cover and hit correct key a few times, you'll see the side that drives the tape moving. The "empty" spool will go on that side. Make sure the flat, not shiny, side goes towards the roller.
Dec 27, 2010 | Olivetti Office Equipment & Supplies
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
Hammers missing the paper
The type-bar basket is not returning to the rest position. The lift springs may be too weak (shorten them), something may have dropped inside the machine to jam the basket, or the up-stop for the basket may need adjusting.
Jan 21, 2010 | Olivetti Office Equipment & Supplies
How to reset the left margin on an Olivetti ET2500 typewriter?
CARRIAGE RETURN TO LEFT MARGIN, THEN PRESS 'MARGIN RELEASE' KEY. THEN BACKSPACE TO WHERE YOU WANT THE MARGIN, AND THEN PRESS THE 'MARGIN LEFT' KEY
Nov 09, 2009 | Olivetti Office Equipment & Supplies
Letters aren't striking ribbon
Get some WD40 and spray it on thw segment (the place where the type bars are swung) then everywhere the key mechinism pivots.
DickyO
Apr 04, 2009 | Olivetti Linea 198 Typewriter
Lettera 22 - sips and adds spaces on occassion
If it skips at the same place or skips every 10 or 12 spaces all the time it is a broken tooth on the escapement wheel or rack. It could be in typing you are lingering on the key causing it to spring back a little ans space over.
Apr 18, 2008 | Olivetti Lettera 25 Typewriter
Return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Dec 27, 2007 | Nakajima AE-740 Typewriter
Olivetti Lettera 35 L Typewriter Logo
273 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Marvin
Marvin
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
