Question about Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television
I have a 2006 Hitachi Ultravision 42 inch plasma
I have a 2006 Hitachi Ultravision 42 inch plasma TV. It's was working fine but now I can only get it to power up to stand by mode. It won't turn on when you press the power button on the side of the TV which is when the picuture would come on. BTW, the TV came with the house I just bought and we have not been able to fine the remote yet so if any of the answers require using the remote I don't have one just yet.
Thanks,
Mike
Posted by mykie_c on
Bill Boyd
    Top Expert:
  • Hitachi Master
  • 53,800 Answers
Plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Posted on Jun 24, 2017
5 Related Answers
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV http://www.hitachiserviceeu.com/scripts/userguide.php/CL42PD2100_EN.pdf if it is a different set please check the model number, this should have a 42 in it (as it is 42")
Posted on Sep 27, 2007
tom sh
  • 1141 Answers
SOURCE: hitachi manual needed hitachi owners manual or user guide
Hello there
Here is a link to all Hitachi Plasma Tv manuals user guide owners manual and so on
I couldn't Find your model so perehps you should check again, but no worries the link is for ALL manuals so Enjoy It.
http://www.hitachiserviceeu.com/support/guides/userguides.htm
Tom
Posted on Oct 08, 2008
Anonymous
  • 11 Answers
SOURCE: Need a pedestal stand for an AKAI 42" Plasma
do you have the small feet as shown in the picture? are they in your closet?
ebay?
Posted on Nov 30, 2008
Big Hev
Dennis
  • 64 Answers
SOURCE: Vertical Green Bar 3" wide on the right side of my 42" plasma
My thought is that it is an Intergrated Circuit (IC). But it has been brought to my attention that it may be as simple as adding a "ground adapter" to the plug of the TV. If after you try changing out the ground adapter and it doesn't work, try "power cycling" your TV. (unpluging it... Waiting 30 seconds, then plug it back in.) If that fails, contact Hitachi so they can recommend an authorized service center in your area. Hope this helps. Good luck, KMarshall!
Posted on May 25, 2009
Anonymous
SOURCE: 42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
Posted on Jun 03, 2009
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Jan 04, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I have a Hitachi Ultravision, 42 in. plazma tv hooked to cable. The cable is working but I cannot turn the TV on.
Hitachi has a master and a slave power button. Like a computer, one switch on the back and a power button on the front. Look near the tv stand for a button or a flap. of even by the menu botton.
Jul 17, 2009 | Televison & Video
Tv won't turn on
ether the lamp needs to be replaced or you have a bad capasotor on your power board
May 28, 2009 | Hitachi UltraVision 42HDS52 42 in....
May 25, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
I have a 50 inch hitachi ultravision that has no picture or sound but power light is on
you have lookse connection on the video convergance amp ic
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 04, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
