Question about Toshiba 53H71 53 in. Rear Projection Television
Hi there ive got a toshiba 43vj13p very blue picture
Hi there ive got a toshiba 43vj13p which turns on fine but the picture is mainly blue the blue crt can be turned up and down via the pots on the control board as can the other colours but the red and green dnt seem to be very efficient also wen looking at the rear of the crt tubes the red and green dnt seem to have as much of a orange glow as the blue any help would b gr8 thanks james
Posted by storey1979 on
Anonymous
    New Friend:
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Posted on May 07, 2010
I have bought a one for all remote and the codes wont work for my toshiba 43vj13p tv
Just check it with some other codes to different brand remote control. This is a common problem with Toshiba brands. If you wish to get more codes to different other brand remote controls, check this link. Setup codes and proceedings to many brands of popular remote controls are given in detail. Check this link too. Pull up older posts there.
Feb 23, 2013 | Televison & Video
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
Hi, is this an IC chip problem?
Yes that chassis should use STK392-110 you need to replace both heres a link where you can get new replacement ICs and they provide free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 43vj13p
if the people in the pic has red out lines or looks like theres two of them then sounds like convergence problems which you will need to replace the convergence chips which cost around £150 +vat. hope this helps
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Picture blurry
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
try doing a magic focus
Dec 10, 2007 | Toshiba 43H71 43" Rear Projection...
Sond no picture
try this
sounds like the teletext module's
http://forum.eserviceinfo.com/viewtopic.php?p=4626
Dec 07, 2007 | Toshiba 42H81 42" Rear Projection...
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
184 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
