Question about Frigidaire FTF530FS Front Load Washer
Washer is not spinning fast. It spins just not fast enough to get the water out of the clothes.
Posted by workj28 on
Jim Wirth
    Novelist:
    Scholar:
  • 100 Answers
Most washers have a speed limiter in them to prevent the unit from damaging itself "IF" it is severely out of balance. Your solution is to redistribute the load, so it will not be out of balance and/or wash smaller loads so the machine can redistribute the load itself.
Hope this helps..
Kindly,
Jim
Posted on Dec 21, 2009
  • ashakv Dec 18, 2010
    I had this issue. Problem is probably with door lock and switch assembly. Google "error codes" for your washer and you will find how to check if this is it. Even if the "error code" does not indicate it-it is still worth fixing. You CAN DO IT BY YOURSELF. Remove the hoop around the boot. Remove he boot. Look in the door lock space and unscrew the assembly-easy to do. Gently pull it out and disconnect the 2 or 3 electrical plug-ins. Replace with new part in reverse order. Part is about 80 dollars and available on-line or in local store. Takes literally 15minutes to do and I can' t fix anything!
  • Jim Wirth Dec 18, 2010
    There is a speed limitation feature that protects the unit from spinning to fast when it is OUT OF BALANCE..... You can solve it one of two ways. 1.) Make the load smaller so not to trigger the Speed Limitation Sensor. "OR" 2.) Stop the washer in mid-spin, redistribute the load so it will not spin OUT OF BALANCE and you will be pleased.... Kindly, Jim
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Kenmore Automatic Washer Model 110.24642300 - problem is that spin cycle is not fast enough to get the water out, so clothing is sopping wet and loose at the bottom of the tub instead of plastered to the...
Your transmission is starting to go bad. It is not creating enough power to spin the clothes fast enough to dry them. It is cheaper to look for a new washer . To fix the transmission will cost you over 400 I would do light loads until your able to get a new washer
Jul 12, 2011 | Washing Machines
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Kemore washer
If the machine spins but not fast enough you will need to replace the clutch.
Jan 05, 2009 | Washing Machines
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
770 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
