There is a diagnostic light on this model that will bling an error code on the circuit board. Without removing a panel, look for a small viewing port and a blinking light. Once you have found it, look on the wiring diagram for a error code chart. This will give you a starting point. If you are getting glow from the igniter but the gas valve is not opening, you could have a bad igniter (not producing enough heat to trigger the sensor). There may be an issue with gas getting to the gas valve as moyerboy2 mentioned. The gas valve could be turned off or restriction in the gas line. Check all shut-offs and your tank if propane. Check all electrical connections at the gas valve and follow the wires back to the circuit board. Tap on the gas valve when the igniter glows, maybe something is blocking the flow of gas. Hope this helps.
Be sure that that PVC vent pipe going outside is not plugged or trapped with water. If the vent pressure switch is not tripping the furnace will not ignite. Also be sure that you don't have a gas leak somewhere causing weak gas flow to furnace.
