If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input.
Dual Inputs
Step 1
Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and
DVI or
HDMI output.
Step 2
Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3
Plug the DVI or
HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1
Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2
Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3
Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4
Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5
Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6
Turn the computers and monitor on to verify the connections are correct.
Required Items
- VGA cable
- DVI or HDMI cable
- KVM switch
- Power strip (optional)
Iām happy to help further over the phone at
https://www.6ya.com/expert/arturo_82cd53a2264b6f81
