- Unplug the power
- Remove the the range plates
- Lift the front of the range lip gently and not much.
- You will see a cardboard covered piece.
- Pull down the door and unscrew the two front screws where the latch is
- Unscrew the bottom screw below the two front screws.
- look under the range lip and lift up the cardboard case
- use your finger and push the inside of the metal piece within the cardboard case.
- you will hear the latch click which means it has been reset.
Note- it looks confusing, but worth it if you want to save on a tech charging you hundreds of dollars. trust me, they will use the same procedures I just metioned
- Reverse the steps to put your stove back together.
- You may want to cover that clean option on the stove. this is what causes the F9
Hope this helps
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
