Question about Necchi Sewing Machines
We have a very old Necchi Model BU Mira, that is integrated into a sewing table. It has a knee pressure speed control. There is no power cord, so I'm trying to figure out where to connect one. It appears there are 2 possibilities. One is a power block on the motor mount, but that appears only to make sense if there is a foot pedal speed control (not the knee kick). The other is where 2 blue wires from the transformer (primary?) connect to a terminal block underneath the machine. I looks to me like the knee pedal would short the power if it came from the power connector on the motor mount housing. Is the blue wire pair from the transformer where power should come in? Thanks, Sherrie
Posted by brokentiles on
Anonymous
    New Friend:
The power wire (from the wall) connects to a block just under the motor where the on/off switch is. On my machine there is a brown block with the words Necchi italy on it. I unscrew two screw and there is a track were the power cord lays and leads bite in to the cord as the screws are retightened..... The blue wires from the transformer are on the "sewing machine side" of the transformer and power from the wall should not be attached there.
Posted on Feb 28, 2010
I would like a wiring schematic for the speed control transformer and light on a old Necchi Mira sewing machine, please.
the light wires are not to be connected to the speed control but have a separate circuit to the on / off switch
if you have the light connected to the speed control then as the resistance to the motor is decreased it affects the power available to the light
May 31, 2016 | Necchi Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
Where to I connect the foot controller on this necchi bu mira sewing machine??? Cannot find where it connects anywhere.
is that a belt driven machine if so the foot pedal controls the motor hanging below the machine
Jul 20, 2015 | Necchi Sewing Machines
I need to purchase a flat bed case for Necchi bu mira
You can go purchase one on line at Sewingpartsonline.com for $35.95 or your local sewing machine store should have. Sometimes ou can find them at Walmart also.
Oct 12, 2014 | Necchi Sewing Machines
How do i set a necchi bu mira to sew vinyl
Vinyl will stick to the presser foot so either pit talcum powder on the vinyl or have a toilet roll on your lap and sew the toilet roll on the vinyl then peel it off
Oct 04, 2013 | Necchi 3102 Mechanical Sewing Machine
Need manual for nechhi sewing maching #4575 code150t
http://userguides.50webs.com/
They carry manuals for almost every sewing machine ever made.
If they don't have it, they usually will tell you where you could get it.
Jun 15, 2009 | Necchi 4575 Mechanical Sewing Machine
Necchi machine
Bu Mira was made in Italy between 1952-1956 it was the machine where the introduced the Wonder Wheel to make decorative stitches, olive green in color . There are some people who collect them but like all antiques the rearer the are and the better origonal condition the are in the more the are worth.
Aug 02, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
823 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
