Question about GE Freezers
I have a frigidaire fridge with top freezer model #GLRT13TEW4. The freezer was icing up and had frost hanging from the top. So I replaced the defrost censor and timer. It worked great for one day. It turned off automatically and I was happy. Now its freezing up again,it won't seem to stop running and it's not getting cold in the bottom. What else can it be?
Posted by rosalozaw on
John Brumenschenkel
    New Friend:
    Problem Solver:
  • 15 Answers
Gaskets can cause this, along with internal fans getting bad or iced over. Other answers might indicate a leak of freon.
Posted on Sep 29, 2017
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
Anonymous
  • 1122 Answers
SOURCE: Hotpoint FAZ50 Frost Free Freezer
IF NOT THE THE DEFROST TIMER YOUR DEFROST HEATER OR DEFROST TERMINATOR IS BAD,REMOVE BACK PANEL INSIDE THE FREEZER YOU WILL SEE A LONG SINGLE OR DOULE POLE SHAFT THIS IS YOUR HEAT REMOVE BOTH LEADS ONE ON EACH END PUT YOUR VOLT METER ON OMES AND PUT ONE LEAD ON EACH END IF YOU GET ANY KIND OF READING YOUR HEATER IS STILL GOOD AND THE LITTLE ROUND CLIP ON TERMANATOR IS BAD, IF NO READING THE HEATER IT IS BAD,REPLACE-GET THE MODEL NUMBER INSIDE FREEZER AND GO TO LOCAL APPLIANCE PARTS STORE TO GET HEATER-REPLACE AND PUT BACK TOFETHER AND YOU SHOULD BE GOOD TO GO,ALSO MAKE SURE THE FREEZER FAN IS NOT STUCK AND TURNING,IF NOT TURNING SPIN IT WITH YOUR FINGER AND SEE IF YOU CAN GET IT GOING AGAIN,LET ME KNOW
Posted on Jun 15, 2008
Anonymous
  • 86 Answers
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Posted on Jan 02, 2009
Anonymous
  • 212 Answers
SOURCE: side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Posted on Jun 24, 2009
Anonymous
  • 121 Answers
SOURCE: Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Posted on Jun 29, 2009
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
I have a Frigidaire A Rated Frost free fridge freezer Model FRC150FF 13 months old. I have noticed a build up of ice under the bottom drawer of the freezer compartment in the last few weeks. It is easy...
there is a chance that the drain hole in the back of the freezer is plugged or block and needs to be clean when the unit is defrosting the water is dripping in the cabinet instead of out the drain.
Feb 27, 2011 | Frigidaire Freezers
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fridge not cold enough and frost buildup in the
Your problem is probably one of the following:
* defrost thermostat
* defrost heater(s)
Contact an appliance service company.
Feb 16, 2010 | Frigidaire Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Side by side fridge not cooling, not making ice
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Whirlpool Fridge Model WRX57H Defrost Timer
if you couldn't find a defrost timer then just unplug it or switch it off until all the frost (ice) melts!
Nov 19, 2007 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
313 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a GE Freezer Expert? Answer questions, earn points and help others
