Question about Samsung Bluetooth?® WEP200 Headset (81451TMIN)
Samsung wep 200 headset
I there i ahave recently bought the wep 200 and paired with my phone but cannot get it to answer automatic checked settings on my phone all ok is there reason for this thank you ian holmes
Posted by ianholmes354 on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
Posted on Jan 22, 2010
1helpful
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Thank You
2helpful
How do i connect samsung wep 200 bluetooth headset to my nokia 3110c
all you need to do hold doown the on button of the samsung wep 200 bluethooth for about 5 sec, till the headphone will enter searchmode, which the led light will be blinking continiously. note:- its possible for it to change color or it may be the same color
then immidiately you see that blinking continiously like that, turn on the bluethooth of your phone and search for audio device around or new pairing, then you will see the name of the samsung headset and now click the name on your nokia phone and it will ask you if you want to pair the device say yes and it will ask you for password its either 1234 or 0000 and thats all.
rate this
11helpful
How do I pair my WEP 200 samsung bluetooth to my phone blackberry phone
Your phone MUST have the bluetooth on and discoverable. When it is press and hold the power button on the WEP200 until the light turns on steady should be 5 to 10 seconds. With this done, use your blackberry to search for a new device, should be in the bluetooth menu. It should find the headset. Your phone will ask for a password enter "0000" (four zeros) then press pair or enter. It will take a few seconds to connect. Your phone will automatically connect to this headset when you power it on. Don't forget to turn the phone back to un-discoverable when done. I hope this helps.
Dissconnect of WEP200 with Nokia 5300
I AM CONNECTED WITH WEP 200 TO MY NOKIA 6233 BUT IT IS NOT WOKING MEANS I AM UNABLE TO HEARING
3helpful
2answers
Wep 200
first switch off the headset and then press and hold the multifunctional button for 10 sec then the blue light gets constant then u search frm the phone
the code is 0000
Wireless bluetooth headset
  • press the answer button at the side of the headset
Samsung Bluetooth?® WEP200 Headset (81451TMIN) Logo
Top Samsung Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Samsung Camera Expert? Answer questions, earn points and help others
