Question about Caravell Bulova Caravelle watch
PIN FALL OUT LADIES WATCH
PIN JUST FALL OUT I DON'T WEAR IT THAT MUCH PIN PUT IN BY THREE TIME ALREADY IT IS NOW BROKEN HOW CAN I HAVE IT FIXED OR JUST A NEW WATCH I HAVE HAD IT A YEAR I THINK THE JEWELERY HAD IT 8-9 MONTHS OUT OF THA YEAR
THANK YOU
MARY ANN
Manual for a Timex T5K360 Ladies Marathon Watch
Google (timex)(T5K360)(manual) without parens.
May 26, 2018 | Timex Watches
Set date/time on a timex triathlon ladies watch.
Hi ccj19cjj,
If you don't have the manual, this is the direct link to all Timex watch instructions/manual:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Hope it helps.
Thank you for using FixYa.
Jul 12, 2011 | Timex T45181 Watch for Men
I have a Relic ladies watch that I wear all the time and just love. I recently had the pin to brake that holds the watch to the band. The jewelry store repair man had to drill the pin out to replace it...
mcdevito75 here, That pin is called a spring bar and is used to hold the band to the watch, the pin must be frozen in place on the watch, Best Bet is to try another jewelery shop, in the meantime you can put a drop or 2 of cooking oil on the pin just as it meets the watch this may loosen the remaining portion of pin.
Aug 07, 2010 | Relic Watches
I have 4 seiko watches that no longer work. Most unreliable watch
mcdevito75 here, hello Diane, I'm afraid your jeweler is correct, and so are you. It is adviseable to pull the stem out to save the battery BUT, only if your not going to wear your watch for a long time, not just over night, here"s the problem!! the quartz mechanism and most of the works are plastic, and plastic while fairly flexable when new, gets hard over time, your pulling the stem to stop the watch everyday or even once a week most likely broke the switch in the mechanism that starts the watch, if so your only option is to replace the movement if you can get one. Pull the stem to stop your watch only if your not going to wear your watch for say 2 weeks toa month.
Feb 06, 2010 | Seiko Ladies Two Tone SUJ614 Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
Jan 02, 2009 | Gucci 1500 YA015512 Watch
How do I adjust my time
hi friend,
i think your rolex watch must be a automatic one. this kind of watch, you don't need to put battery, after in full power, i can last 24-48 hours. if you wear it, it will not stop, but if you don't wear it for long time, it will stop automatic. to adjust the time, you just need to wind the crown counterclockwise, and then pull out the crown, and then you will hear the sound of "click" and then find the right position, and then wind the crown to change the date. please note that the date have to change from small number to big number. after adjust it, you have to screw down the crown to a good water proof capability.
source form: Swiss ETA watch
Sep 30, 2008 | Watches
Caravell Bulova Caravelle  watch Logo
158 people viewed this question
Top Caravell Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Caravell Watch Expert? Answer questions, earn points and help others
