Ps3 when turning on will turn yellow, turn off and start blinking, and the disc will not eject.
Yellow light of
death. Here's a link to my step-by-step instructions on how to fix the problem.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Does the lights blink red? If so, You
have the infamous YLOD, aka. Yellow Light of Death. This is the
number 1 cause of pS3's dying. It is an overheating issue linked to
your CPU and GPU (the processor chips) You will need to find a local
PS3 repair shop who can repair this. Do not try to attempt repairs
seen on the internet yourself as some would suggest.You could make
things much worse and render the unit totally unresponsive. The
repair process takes about 3 hours.
IT CAN BE FIXED*
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not
backwards compatible, any non 60g or 80g then you can retrieve your
disc.
Power off the unit using the toggle
switch on the back. Hold down the 'eject' button and turn the toggle
switch back from off to on. This will run a fan test and eject your
disc. Remember, this will only work on the 20, 40g models. Not the
backwards compatible units with the 4 usb port holes and the memory
card slots.
You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
Does the lights blink red after turning yellow? If so, you
have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of
pS3's dying. It is an overheating issue linked to your CPU and GPU (the
processor chips) You will need to find a local PS3 repair shop who can repair this. Do not
try to attempt repairs seen on the internet yourself. You could make
things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
can retrieve your disc.
button and turn the toggle switch back
and eject your disc. Remember, this
usb port holes and the memory card slots.
