SOURCE: KENWOOD KDC-W6537U
Hi there
You can get the instruction book from here
http://www.kenwood-electronics.co.uk/WebFiles/File/uk/download/Instruction%20Manuals/KDC/KDC-W6537U.pdf
Page 29 tells you how to turn off Demonstration mode. Blue toothe operation is well detailed also. Good luck. Any problems, I have downloaded the manual to help you. :)
regards
Graeme.
SOURCE: Kenwood KDC-MP438U and Nissan Pathfinder Steering wheel controls
you need an aftermarket PAC!
it will work just fine!
SOURCE: need the unlock code
All Kenwood Radio Codes are available online sameday service via serial number
Visit www.instant-radio-code.co.uk
SOURCE: Kenwood KDC-319 CD Player Code dont have a
dont put a code all those radio say that when first power up just push the source button to do what you want
SOURCE: Kenwood KDC-MPV619. No remote. Need unlock code for deck.
I had the same problem with my kdc-mpv619. I had bought a new truck that didn't have a remote and the screen says enter code. You do need a remote to fix it, but what they don't tell you is a universal remote will work. I used my direct tv remote and looked up all the codes for kenwood.
The one that worked for me was 30337 (not sure if that would work for you).
1) The way I tested it was go to my stereo and I held down the display button + volume up button. (This should remove the - - - - sign but it will still say CODE).
2) Then you press the 5 button on the remote and if the screen says CODEK then you know the remote works.
(to switch from K to C to A to R press the (>>) button on the screen.
3) Enter the code KCAR (the display will say CODEKCAR)
4) Final Step is hold do the fast forward button (>>) on the screen.
It should work for you after that ;-)
