Question about Kodak EASYSHARE 5100 All-In-One Printer
My printer prints photos great but when it comes to text it comes out blurry. Like only half of the letters meaning half of a letter is being printed.
Posted by jehcorp on
Anonymous
    New Friend:
Alignment problem with jets. run maitenance program in printer software
Posted on Dec 20, 2009
Prints letters blurry as if you pass the brush.
How blurry? Like toner can be wiped of or like the letters are verry light?
Did you check pressure between fixing and pressure roller, it could be the bad bushing that causes the problem.
If they are very light, clean optics.
Jun 30, 2010 | Canon PC170 Copier
Imprime letras borrosas como si se le pasara la brocha.
Do you mean blurry, like toner isn baked, or ...
If yes, dispite the good conditions of fixing roller, you may want to replace bushings of fixing rollers too. Because they do not generate enough pressure.
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Lodak Easyshare 5500
More than likely doris you have an issue with the black text not printing. Press copy and photo at the same time. Look at the eyes of the kids in the picture. They're probably all white. Clean the printhead from the main menu. A deep clean. Print another demo. If it comes out the same, you need a new printhead. Call Kodak.
Sep 28, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
Sep 12, 2008 | HP DeskJet 5740 InkJet Photo Printer
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to...
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Aug 21, 2008 | Kodak Office Equipment & Supplies
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Kodak EASYSHARE 5100 All-In-One Printer Logo
201 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Muntejaya Ginting
Muntejaya Ginting
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
