Question about Canon CanoScan N1240U Flatbed Scanner
Need driver for canoscan N124OU for windows 7
  • 424 Answers
Alternative driver download link: Canon CanoScan N1240U Scanner Driver
Posted on Jan 25, 2010
  • 557 Answers
    New Friend:
The best solution I have found is to install a virtual machine running Windows XP: if you have kept your old XP disk and the license number from the bottom of your old PC, then it is relatively easy to set-up using VMware player see instructions here http://www.howtogeek.com/howto/11060/create-an-xp-mode-for-windows7-home-versions-and-vista/.
Once installed, you can basically start windows XP in a window, and install your old scanner driver (and any other XP software for that matter) and it all works like a charm!
Posted on Aug 28, 2012
2 Suggested Answers
amstyl
Amstyl Polycarpe
  • 62 Answers
SOURCE: I have windows 7 and
Canon has no driver for CanoScan N1240U on its website for Windows 7. But, if you want to try with the one for Windows Vista, you can find it here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
Posted on Apr 16, 2011
greed03
WTF Chuck.....
  • 387 Answers
SOURCE: Need Driver for a Canon
Here's the Canon site for your drivers
Hope this helps!
Don't forget to rate:)
Posted on Dec 20, 2010
I have windows 7 and the cannon scanner canoscan n124ou is there a driver for windows 7?
Apr 16, 2011 | Canon CanoScan N1240U Flatbed Scanner
I NEED TO INSTALL MY CANOSCAN N124OU ONTO MY WINDOWS7 COMPUTER
go to this site: http://support-th.canon-asia.com/P/search?model=CanoScan+N1240U&menu=download&filter=0&tagname=g_os&g_os=Windows%20Vista
However, i dont think it is compatible with windows 7.
Apr 04, 2011 | Canon CanoScan N1240U Flatbed Scanner
Trying to load CanonScan N124OU onto Windows 7 and get error message "there is no application registered for this event"
canon scan n1240u will work on Win7
here's how:
go to this site: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
click "Drivers and Software" then select OS "Windows XP" then download "WIAdriverN670UN676UN1240U.EXE"
Install the WIA driver on your Windows 7 OS and used only mspaint to capture image on the scanner
TWAIN doesn't work on Win7 but WIA still doesGood Luck!
Dec 06, 2010 | Canon CanoScan N1240U Flatbed Scanner
I just unstalled Vista Ultimate, and I cannot find any drivers for my Scanner N124ou lide 30N; the set up disc I have is for windows XP advice
They did not make a win 7 driver yet, so you can try the vista driver, not sure if win 7 will allow it but does not hurt to try, sometimes it will error
OS not supported.
Here is the vista driver on the canon website below.
You can also plug it in and go to devise MGR and have it update the driver, if windows see's it, or when you plug it in windows might ask if it can search for one.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6626
Feb 11, 2010 | Canon CanoScan N670U Flatbed Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
Help
Yes you need at the minimum the drivers to use this. You can find them and probably the whole operating system over athttp://www.driverguide.com ,,http://crownpc.no-ip.info
Nov 07, 2008 | Canon CanoScan N1240U Flatbed Scanner
Canon CanoScan N1240U Flatbed Scanner Logo
15,107 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
