Hi and welcome to FixYa,
May I offer an alternative approach?
Initially, determine and postback the brand and model number of the TV unit.
Offhand, some TV units require that the external/audio out particularly the digital has to be enabled. This is so that the TV may also control the volume level of what is fed to the receiver/amplifier. On some other instances, the Audio Output of the TV must be switched from analog to digital.
Good luck and thank you for asking FixYa.
Sony BRAVIA series of TVs would have model numbers something like KDL40S2010.
Still, most BRAVIA models would have a (digital) OPTICAL OUT and an AUDIO OUT (VAR/FIX) (analog). What is important to note is that digital audio out is only available if what is shown on the TV is a digital channel on some models.
Hello. Yes the setting would be digital audio. regards, Joe
I don't see that option on the receiver. I don't have a dvd player. Just the tv. When i was using the analog cables they were hooked in under TV/SAT. There is a setting for TV/SAT on the front that i kept i would have it on. The optical in stands alone...it just says Opt. 1/pcm - digital in
when i was using the analog cables i had them plugged in under TV/SAT in the back of the receiver. There a setting that corresponds to this on the front that say TV/SAT that i kept it on.
The optical input just on it's on...i don't see a digital audio setting in front
can someone else please assist. Thank you.
thanks...but how do u set the receiver to output?
I don't see an option for that dig/opt on the front of the receiver? could it be called something else?
the receiver has the following buttons/settings
Class Memory MPX mode Dolby Pro Logic Disp Mode
Signal Select Midnight Mode
VCR DVD/LO TV/SAT VIDEO CD FM/AM
please help
the model name is Optimus STV - 3790
sorry that was the model of the receiver
Model of TV is Sony Bravia
