My Denon AVR-788 receiver switches off by itself after it has
My receiver, which is 2 years old switches off by itself after it has been on for a period of time. After turn it on again, it turns off within a few minutes. If I wait an extended period of time to turn it back on, it stays on for a while.
We called Denon, and they said it could be a wiring problem. This doesn't make sense as it was professionally wired over a year ago, and the problem began about a month ago.
Posted by danmed on
Mike LaPres
  • 757 Answers
If you've changed it's location or added speakers, or placed anything on top of it since the problem started then consider that it may just be over heating.
Posted on Dec 20, 2009
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Tengo un receiver denon avr1609 y quiero restaurar los valores de fabrica como puedo resetear
uno de los tres por debajo de las soluciones de trabajo para que el receptor
1. Para reiniciar el sistema, a su vez el receptor apagado por el peque?o bot?n on / off, no el bot?n de espera grande. Mientras que fuera de noche y pulse el bot?n directo puro, a la vez y sigue tomando con su mano derecha mientras presiona el peque?o bot?n on / off con la izquierda. Ver? el flash men? del receptor. Cuando lo ves flash dejar ir de la noche y botones de acceso directo puro y el receptor se reiniciar? si mismo a la estaci?n de radio 87.50.
2. Pulse el bot?n "Power" al mismo tiempo presionando el bot?n "Standard " y "Simulaci?n DSP" en el panel frontal de su receptor Denon. Estos botones tambi?n pueden estar ocultos debajo de un panel tir?n en funci?n del dise?o y el modelo de Denon que se utiliza. Algunos modelos de Denon requieren diferentes combinaciones de bot?n que se pulsa simult?neamente mientras se presiona el bot?n "Power", como el "Modo Surround" botones. Algunos modelos de receptor Denon no proporcionar? las instrucciones de restablecimiento en el manual del usuario, para encontrar las combinaciones de bot?n derecho debe ponerse en contacto Denon.
3. Pulse el bot?n "Power" para apagar el AVR-
Pulse el bot?n "Power" al mismo tiempo la tecla "altavoz A "y "Speaker B" botones. Espere a que el AVR-788 a la pantalla comenzar? a parpadear a una velocidad de alrededor de una vez por segundo.
Suelte los botones despu?s de la pantalla comienza a parpadear. El AVR-788 es ahora restablecer la configuraci?n predeterminada de f?brica.
2helpful
Denon avr 788 power switches off by itself quickly with power standby button flashing
Could be a short on one or more of the speaker outputs. Try disconnecting all speakers and turning the unit on. If that works without a power-down then you have a short in one of the speaker connections. Re-connect them one at a time to detarmine which one it is, and then you should be able to correct the problem.
If that is not the cause then you have an internal problem with the avr which would be difficult to diagnose here.
2helpful
1helpful
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
2answers
Need the manual
Check the link below:
AVR-788
Denon AVR 2106 amp failure
Does it still power up for a little bit or so with no sound what so ever?....I there is no dents in it or metal pushed in causing cracked connector boards....I can take it off you hands for a couple parts I need ...because your transformer and 2 resisters are shot and it will cost almost as much as the unit cost's.
I do have a brand new never opend $649.99 Denon AVR-788 for $365.00.
And 2 used AVR units Denon and Onkyo.....ALL HDMI
call 630 742 6587
1helpful
2answers
No code for Denon AVR-788 receiver remote through Cox cable.
Denon AVR - 788
Code for DirecTV remote RC64
The code I have found for this one is 31360 and maybe 31104.
Marvin
Marvin
