Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to
flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 =
Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 =
DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
