Maytag MEW6630D Electric Double Oven Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a maytag gemini double oven and the bottom oven door will not open
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Jul 30, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10842515
Points
101584
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
My 2008 Maytag double oven the lower door is locked, no messages on display and the manual says to push 'CANCEL abd Cook & Hold' button but does not unlock the door
f your 2008 Maytag double oven's lower door is locked, here are some steps you can try to unlock it:
Press Cancel/Off Key: Start by pressing the Cancel/Off key. Wait for 20-30 seconds, then try to open the door. Sometimes this simple latch reset can do the trick.
Power Cycle: Turn off the power at the circuit breaker or fuse box for one minute. After that, turn the power back on. Allow the oven to cool for approximately 30-90 minutes, and then move the latch arm to the left to unlock the door.
Self-Clean Cycle Interruption: If the door locked during a self-clean cycle, select the "Self Clean" option, and then choose "Cancel". Wait a couple of minutes, and then try to start the cycle again. If the self-clean cycle was started by mistake, press the Cancel/Off key. The oven will need to cool to around 200°F (95°C) before the door can open.
Remember to ensure that the oven is cool and the power is turned off before attempting any of these steps. Hopefully, one of these methods will help you unlock the oven door! Your manual might prove helpful. Oven is Locked - What to Do - Product Help ' Maytag
Defy Gemini Gourmet Multifunction Thermofan double oven. The top oven is not heating up?
Question edited for clarity and toss in a load of CAPS.
Disconnect the element and the fan and check them both for continuity with a multimeter. If the circular element or the fan fails, nothing works, so it could be either.
https://www.google.com/search?q=defy+gemini+gourmet+multifunction+thermofan+double+oven+not+working
Defy Gemini Oven Thermofan Element
appliancepartswarehouse.co.za https://appliancepartswarehouse.co.za > ... > Elements
Fits most Defy Gemini range ovens ie. Petit Chef, Gourmet, Multifunction & Masterchef. Like us on Facebook. Check out our other spare parts. At Appliance Parts ...
ZAR 803.85
DEFY GEMINI MULTI CHEF BAKE ELEMENT
BRIGHTS Hardware https://www.brights.co.za > ... > STOVE & HOB PARTS
DEFY CARBON FILTER COOKERHOOD. R 299.95. VIEW PRODUCT · Defy Thermofan Thermal Cut-Out. R 114.95. VIEW PRODUCT · OVEN GASKET 4SIDE DEFY 118/418. R 119.95. VIEW ...
ZAR 259.95
BAKE ELEMENT DEFY GEMINI / GOURMET
MacSpares http://macspares.co.za > ...
Home :: Stoves and Microwaves :: Oven Elements :: BAKE ELEMENT DEFY GEMINI / GOURMET. Oven Elements. Product 17/134. BAKE ELEMENT DEFY GEMINI / ...
ZAR 391.50
Dec 12, 2023 • Ovens
Maytag model CWG3600AAB error code f2
There doesn't appear to be an F2 error code! There is an F1-2?
https://www.google.com/search?q=maytag+gemini+double+oven+error+code+f1-2&
There may be a problem with the Lower Oven Temperature Sensor, the Control, or the associated wiring.
Maytag - F1-2 - Product Help
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
heatman101
Problem with my maytag gemini double oven
You have an oven sensor shorted or poor contact at the EOC,(electronic oven control).
Jan 27, 2010 • Ovens
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Maytag double oven-top cleans itself-bottom reads unavaiable?
Either BOTH cannot clean at the same time b/c they heat to 700deg and use alot of power, OR the 'Door secure' signal from the bottom oven is not getting to the controller. I suspect if that is the case, the switch is on the inside of the door, activated by the LOCK lever moving into locked position. It may be a beny switchlever, mis-adjusted LOCK lever or solenoid or disconnected wire.
If you leave the TOP open and force a clean, does the bottom lock and do nothing? (My other theory)
Maytag stove will not open after cleaning
is the oven completly cooled down? the latch is hat sentisive the oven must be cool before the latch will open this can be from 15 min to 2 hours after the clean cycle is complete
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
