Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up. Good luck!
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
