Quantaray Rapid Battery Charger with 4 Rechargeable AA Batteries - 1-Week Holiday Sal Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you know when the batteries are charged in the Quantaray AA battery charger?
Anonymous
Level 2:
  • Expert 288 Answers
  • Posted on Dec 19, 2009
Anonymous
Expert
Level 2:
Answers
288
Questions
0
Helped
96611
Points
650
The red lights will be solid instead of flashing
1helpful
Do i leave my radio on the charger all the time?
You didn't say what kind of radio or charger. If it's a "smart charger" and the radio has Lithium or NiMH batteries, it's not a problem. You should, however use the radio without charging it occasionally until the batteries have been mostly (but not fully) discharged. Ultimately that will give you the best life from your batteries.
If you're just using a "wall wart" charger. Only charge the batteries when they need charging, or before you know you're going to use the radio for a period near the maximum time it's rated to operate.
You probably ought to consider getting a battery pack that can accept "AA" batteries as a "spare". You can find AA batteries everywhere, and although they're not rechargeable (for the most part), they'll last longer than your rechargeable batteries - for one use. There's a reason the "Wildland Fire" people use nothing but standard AA batteries in their radios.
7helpful
2answers
HI I PROBABLY THREW OUT THE INSTRUCTIONS. SO HOW DO I KNOW WHEN THE CHARGER CEF 15NC HAS COMPLETED CHARGING THE BATTERIES?
gripfitter is incorrect, that charger is made to charge in 15 minutes. It has a cooling fan and when batteries are inserted a red light comes on and the fan starts. When light goes out and fan stops, the batteries are charged. (light should not blink as that indicates one or more of the batteries has a problem)
1helpful
I have an Energizer E2 Slider battery charger, Is the green light supposed to stay on when charging. Does it shut off when charge complete.
all chargers show a light of some colour when charging , green or red , depending on make of charger , when the battery is fully charged the unit monitor this and automatically switch of to stop from over charging , a safety feature that has to built in for safety reasons ,
3answers
Motorola talkabout t5700
No, the charger is only usable to charge the rechargeable NiMH or Li-Ion battery which comes with the radio. Attempting to charge Alkaline rechargeable batteries with this charger could cause the to expode. If your charger is not charging the batteries which came with the units, it could be you do not have the charger cord end plugged in all the way, or the batteries dropped below the initial charge level by setting on a store shelf too long. Most TalkAbouts come with a cradle style charger to hold the radio, and a possible plug to plug into the charge hole. Check all connections, and clean any battery/charger contacts with a pencil eraser. To re-initialize the batteries you would need to attempt 3-5 charge cycles by charging for 8-10 hours, then letting the battery rest for 8-10 hours, repeating 3-5 times as needed. If this does not bring the battery back to life, you need to replace the batteries.
1helpful
Can I charge only 3 batteries in my Quantaray 4 batery charger?
yes,the charger will charge three batteries at a time if you like. three batteries will charge faster than four batteries. you can even charge one battery by itself.
Apr 03, 2009 • Cameras
Do I have to charge 4 batteries at once, or can I just charge 3
If your charger has four separate AA battery charging stations then it can happily (and safely) cope with 1,2,3, or 4 batteries as you wish.
1helpful
Battery type issue
If you have a manual Dakota RZ-2000 then you will need LR44 watch baterries to operate. You will need two of them. Hope this helps.
Top Quantaray Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Quantaray Hardware and Accessory Expert? Answer questions, earn points and help others
