Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All pro heater 170t runs for a couple of minutes.then shuts off and flashes voltage light.what could be problem
It only shuts down because of an overheating condition or the lack of fuel. if you have an ohm or multimeter, check the ohms on the fan and see if you have any resistance. If you do the fan is good but may still not be putting enough air across the heat exchanger to safely alloww the heater to run without causing a fire.
Posted on Dec 19, 2009
Dec 16, 2017 | All-Pro Heating & Cooling
Nov 04, 2017 | Reddy Heating & Cooling
Jan 22, 2011 | All-Pro Heating & Cooling
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 07, 2010 | All-Pro Forced Air Kerosene Space Heater...
heatman101
Dec 05, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Jan 27, 2010 | All-Pro Forced Air Kerosene Space Heater...
Dec 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
May 06, 2017 | All-Pro Kerosene Garage Shop Heaters - All...
1,217 people viewed this question
